Go Back   Automotive Forums Car Chat > Buick > Roadmaster
Old 07-07-2011, 09:45 PM
bocoogto bocoogto is offline
Engine Misfiring at Light Loads '93 5.7 Engine
At about 1500 rpm in top gear, at a steady speed, the engine misses causing the car to buck. Switching to D2 or third gear, causes this to go away--rpms are higher in D2.
Any suggestions? I've changed plugs, plug wires, distributor cap, rotor. I do have the initial timing at about twice the recommended setting.
There are no codes indicated.
Old 07-08-2011, 03:12 PM
jdl jdl is offline
Re: Engine Misfiring at Light Loads '93 5.7 Engine
Sounds like an overdrive issue. I have a 92 roadmaster, same thing. Mine only does it going up a hill, I just downshift.
I don't know why you have the ignition timing set like that? I guess that is a story for another day.
Old 07-09-2011, 09:51 PM
The problem feels like an ignition misfire.
If the timing is set beyond the 6 degree recommended setting, does this cause other problems? I set it this way because with the reman engine, fuel economy has never been as good as the original engine. I used to get 24 mpg highway. Now it's about 20 mpg.
Old 07-10-2011, 09:28 AM
jdl jdl is offline
Mine is the overdrive, feels like the engine is cutting out. I shift out of od till I gain some speed then back to OD. Always on the same hill, in town, speed limit slows me down.
That timing issue doesn't sound right to me??
Old 11-09-2011, 02:52 PM
I read about a similar problem on another forum related to the EGR valve. I disconnected the EGR and blocked the vacuum line. Problem is gone!!!!
I'm wondering if there are consequences for disabling the EGR. If the only consequence is higher emissions, I'll leave it as is. Car runs perfect!
please help 5.7 liter hawk713 Caprice 1 04-22-2010 08:05 PM
'93 5.7 TBI parking lot speed problem arkansasbowman Yukon 2 03-29-2010 07:02 PM
1996 gmc 5.7 won't start-no spark 600cuin Sierra 5 11-13-2009 12:03 PM
a CHALLENGE!! ('93 5.7 Intermittent no-spark) cmjj42 Roadmaster 3 05-06-2009 11:55 AM
5.7 Engine missing with no code light???? 010175 Suburban 2 04-19-2009 09:45 AM
