Old 07-07-2011, 06:35 PM
fiserman fiserman is offline
Ignition Switch 94 Cavalier
My 94 Z24 Cavalier with the 3.1 liter has an ignition problem. When you turn the key to start it it starts fine but when you let the key go back to its resting position it shuts it off. If you keep the key from going to far back it will run all day but as soon as you let go of the key it may only move a 1/4 inch and then shuts the car off. I know the key is coming back to far, so is there a way to adjust it to keep the ignition switch from coming back to far. Any information would be helpful and pictures even better if it is going to be very complicated.
Old 07-07-2011, 07:20 PM
Scrapper Scrapper is offline
AF Premium User
Re: Ignition Switch 94 Cavalier
it has a broken wire on switch i would put a new key switch in it because because it's broken ground wire maybe pos+ wire you will no when you pull switch out you may even fix switch when you see all wires.
good luck........
Old 07-07-2011, 08:33 PM
It acts like the spring has to much pressure that its pushing the switch postion to far back. Thats why I was really hoping all I would have to do is repostion it. How would the broke wire cause this.
Old 07-15-2011, 03:58 PM
Ok everyone heres an update
Took housing around switch off. Changed electrical part on tail end of switch out. They call it a " Switch/Commutateur Interruptor ". Car starts fine know and stays running. Hope if anyone has the same problem this will help.
Thanks Fiserman
The Following User Says Thank You to fiserman For This Useful Post:
MikeS144 (07-16-2011)
DIC & Ignition Wiring Diagram ugsrich Grand Prix 1 12-14-2010 07:55 PM
Not Starting, did ignition switch - no help Royalwapiti Intrigue 10 02-10-2010 01:37 PM
Ignition Switch mb8668 Eighty Eight 9 11-01-2009 08:41 AM
Anyone know anything about ignition switches? angel_iz378 Cobalt 3 09-08-2009 11:52 AM
