Old 07-06-2011, 12:50 PM
andrew59it andrew59it is offline
Yamaha Tech 3 + Laguna Seca
Hello everyone, this is my first WIP on AF, hope you enjoy it....
These are the kits:
Changed the foot rests
and made some modification
preparing parts with gloss black for carbon decals (quite a lot!!)
Painted Tech 3 with 2k gloss black
and Laguna Seca with automotive diamond white (fiat color)
2k clear gloss
Changed the clutch for the Tech 3 with Top Studio one
Started with carbo decal....
Clear coated the rear fender
ans satin coated the rest
Painted the exhaust gloss black to prepare it to alclad process
Old 07-06-2011, 05:08 PM
stevenoble's Avatar
Re: Yamaha Tech 3 + Laguna Seca
Excellent work, the carbon looks great..!!
Steve Noble
Old 07-07-2011, 07:23 AM
Prepared 2 "soft" tires for the Laguna Seca. From reference it seems this kind of tire has been used
And decalized the tank cover to the tech 3. I need it to match the yellow on the front fender.
It takes about an hour to do it. The decal overlaps in some point and I had to trim the front piece. Probably painting yellow and masking for black could achieve a better result, but I don't want to spend to much time on the Tech 3, something more on the laguna seca.
Old 07-10-2011, 06:30 AM
Mr. Jekyll's Avatar
Mr. Jekyll Mr. Jekyll is offline
Originally Posted by andrew59it View Post
Probably painting yellow and masking for black could achieve a better result...
I agree!
Great work so far!!!
Old 07-15-2011, 12:40 PM
Some progress... fisrt of all some Laguna S. decal to see how they work:
Then the harder job.... as I found some spare decal on the decal sheet for Polini and NEC writing, to match the front fender yellow and decal yellow and to fix the tank I have masked the body with parafilm and airbrushed the decal with pale yellow. The masks were not very close to the decal borders to avoid the paint gap:
Masks removed....
and one decal broken.... (I have to fix it...)
Afetr some cleaning with tothpick with some cotton and alcool and after polishing the fairing this is the result...
Old 08-08-2011, 12:52 PM
It's been a while since last post but I spent many hours to make the 2 cockpit, the frame and the engines....
This is the tech 3
and this Laguna Seca
Tech 3
Laguna Seca
You may notice the different clutches. On the L.S. I have added some pe bolts and nuts.
This is the handlebar
and this is the gauge switched off....
Some fairing
and tank
the L.S. decals are a nightmare. Every decal is an adventure, I cutted the black strips in the angle as they were too close. The side decal had the top edge rounded like the tank so I had to trim them (already wet... ) to follow the black stripe.....
Old 08-09-2011, 02:31 AM
chyknees chyknees is offline
Wow! That is some amazing work. Love it!
Old 08-11-2011, 01:54 AM
rrutherford rrutherford is offline
this has to be one of the sweetest build jobs for an M1 i have seen. Very welldone on the yellow, us modelers just have to be the most adaptive bunch of people there is,lol.
Superb work on the c/fibre, just like the real deal.
Rod
The Following User Says Thank You to rrutherford For This Useful Post:
andrew59it (08-11-2011)
Old 08-11-2011, 06:29 AM
Sorry for the pictures not so good....
Exhaust finished.Detailed only the parts which will show.
I begun to decalize the carbon fiber on the tail cowl. Tamiya leave that black but from references it's not so. A lot of "cut and sew"... For the moment the most important piece for shape a simmetry....
see you tomorrow...!
Old 08-12-2011, 02:16 AM
Finished to decalize the carbon fiber.... it has been a lot of work but I'm satisfied...
Old 08-12-2011, 08:53 AM
Placed all the decals on the tail cowl:
Old 08-12-2011, 01:58 PM
miguel s's Avatar
miguel s miguel s is offline
most of people use clear coat, but i think that satin look better
congratulations
Old 08-12-2011, 02:56 PM
I will clear coat the entire tail cowl but I don't know if after I will be able to satin coat with mask only the carbon fiber...
Old 08-31-2011, 11:10 AM
After vacation finished the wheels. On the L.S. I used some p.e. on the Tech 3 only paint.
L.S.
rear
front
Tech 3
Old 09-04-2011, 09:58 AM
An update on the Tech 3 swing arm:
Tamiya yamaha yzr m1 laguna seca - rossi ALEX GAROLI WIP - Motorbikes 12 08-12-2011 01:48 PM
Yamaha YZR M1 2005 Laguna Seca Version (Colin Edwards) ace91 Completed Projects / Gallery 1 12-16-2010 09:50 AM
Yamaha YZR-M1 Laguna Seca 2005 - # 46 -V. Rossi - Tamiya - 1/12 tom21 WIP - Motorbikes 17 07-15-2009 09:34 AM
Yamaha YZR-M1 Laguna Seca - # 46 -V. Rossi (1:12 Tamiya) tom21 WIP - Motorbikes 11 06-28-2007 08:33 AM
