Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 07-05-2011, 08:55 PM
msvregan msvregan is offline
ac blower motor
Whats up guys. My blower motor recently quit working so i pulled the fan motor out and connected to battery and it works fine. I was wondering if it is a bad datc controller or possibly something else. Thanks for any help you guys could give me.2000 lincoln ls v8
Old 07-05-2011, 09:24 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: ac blower motor
Have you checked for voltage to the blower motor wiring connector? Check with a test light across both terminals as well as from the Red/Black wire to a known good ground. Assuming you do not have voltage across both terminals, I'd suggest you next check the blower motor relay which is located in the Auxilliary Junction Box under the hood. The switched side of the relay is powered by fuse F116 (30A) in the same fuse box.
If the fuse is good, the relay is good, and the relay is getting a command from the DATC module to turn on, then the circuit should be completed through the blower motor and the Heater Blower Control Module. If you do not have power across both terminals but do from the Red/Black wire to a known good ground, then the problem is likely the Heater Blower Motor Controller.
-Rod
Old 07-07-2011, 05:39 PM
joegr joegr is offline
Re: ac blower motor
It is most likely the blower speed controller. It's mounted in the airflow near the blower. It could be the DATC, but usually it is the speed control.
RESOLVED! 98 99 00 01 02 Rodeo Blower Motor problem wbigsby Rodeo | Passport | MU 2 06-12-2016 10:10 PM
2004 Blower Motor Related Electrical Issue... cableguy83 Impala | Impala SS 3 05-24-2011 04:54 PM
1996 Explorer with blower motor issues CREESERFARM Explorer | Explorer Sport Trac 13 02-03-2011 01:13 PM
'97 Grand Prix GT Blower Motor Resistor olopezm Grand Prix 11 06-10-2010 03:20 PM
06' COMMANDER blower motor always runs bclark001 Commander | Patriot 0 03-22-2010 11:39 AM
