Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 07-05-2011, 04:48 PM
Im Lon 2 Im Lon 2 is offline
2001 Chevy Impala P1404 Code.. EGR ?
I'm getting 2 codes P1404, and P0404. Which Auto Zone says is the EGR Valve.
I wanted to ask before I replace it. Is this one of the codes that is given, but could be something else, and not the EGR Valve at all. If so what are some options I should look at first?
Also can the EGR valve be cleaned with Seafoam, if so what is the best way to do this?
The Car seems to be running great. I do get a little bit of a hiccup evey now and then if I feather the gas in traffic.
Thanks Lonnie
Old 07-06-2011, 12:25 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Re: 2001 Chevy Impala P1404 Code.. EGR ?
Go to http://www.obd-codes.com/ , a site that covers all the OBD trouble codes and their causes . Good luck !
" Sometimes I grow so tired "
Old 07-14-2011, 03:56 PM
I didn't see anything on that link.
I changed out the EGR Valve, and reset the codes, 20 mins later the light came back on. P0404 and P1404 yet again.
Old 07-20-2011, 04:14 PM
Woo Hoo Fixed it. Took the EGR valve back off along with the throttle body, and cleaned everything with carb cleaner. Cleaned the MAF sensor with MAF Sensor Cleaner. And Changed the air filter while I had everything off.
2003 chevy impala trouble code 0420 theyard1 Impala | Impala SS 10 10-11-2013 05:32 PM
2001 Chevy Impala Turn Off Message Center Lights w/ Aftermarket Stereo shazbotmark Impala | Impala SS 1 03-09-2008 02:55 PM
help instaling ne ignition cylinder for 2001 chevy impala husani22 Impala | Impala SS 0 09-09-2006 03:36 PM
Location Of Fuel Sender Unit - 2001 Chevy Impala Base Model aswad Impala | Impala SS 3 07-09-2005 11:23 PM
2001 Chevy Impala Problems Mcknwbrdg Impala | Impala SS 4 06-24-2004 06:45 PM
