Old 07-05-2011, 03:46 PM
Festivus's Avatar
Festivus Festivus is offline
Ignition Key Won't Turn
Got a 2001 Alero 4 cyl. Couple.
Almost a month ago that car wouldn't turn over. Did the 10 min passlock procedure and it started. Been OK til today.
So now the key won't turn in the ignition. Won't turn at all. Steering wheel is not locked, car is locked in park. Tried to turn it while moving wheel, shifter, etc. to no avail.
Is this a bad ignition lock cylinder? If so, I've read some procedures on how to replace this thing. It looks horrible. And it seems that one needs to turn the key to get the cylinder out. Is this correct? Remember, my key won't turn at all. Also, is there any way to key it to match the existing keys without taking it to a stealer/dealer? I saw a part on Rock Auto that comes with 2 keys. But I guess then the ignition keys would be different from door/trunk. Is the passlock crap going to give me any issue?
Just wondering what my options are here. Thanks.
Update: Going to get an independent locksmith to fix it for $250 + tax, where it now sits.
2001 Alero 2.4 - 87k - Kid's car - Keeps me busy
2004 Accord EX V6 - 111k - Love this car
2009 Toyota Rav4 Limited V6 4WD - 26k - Wife's car
Old 07-22-2012, 11:05 AM
walkersdad walkersdad is offline
Re: Ignition Key Won't Turn
Thanks for adding the update. I am beginning to have the same problem on my 2002 Alero. Good to know it can be fixed.
Old 07-23-2012, 03:34 PM
Tech II Tech II is offline
Usually what happens is, the key progressively gets harder and harder to turn, until the day comes where it won't turn at all.....you want to fix it before it gets to that point.....
The reason is, in order to remove the lock cylinder, the key must be turnable....if it doesn't, then the cylinder has to be drilled out(special procedure)......
Ignition Key won't Turn Please Help Den S Durango 1 02-11-2007 10:50 AM
97 Cherokee ignition key won't turn pinger1ks Cherokee 5 07-04-2006 11:49 AM
2000 Malibu ignition key won't turn! Help! mdaly_2 Malibu 5 05-16-2006 08:43 PM
2000 STUPID METRO!..ignition key won't turn babyluv04 Metro 6 07-01-2004 08:51 AM
Ignition Key Won't Turn mkdotson Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 03-16-2004 01:43 PM
