Old 07-05-2011, 12:25 PM
ohagen383 ohagen383 is offline
Engine Code P-1345
2000 chevy astro I have an issue that i am trying to resolve I replaced the intake gasket and also marked the distributor and when I started it I was slow to start i am thinking that some how the ignition timing got off. any suggestions on how to get the timing back right
Old 07-05-2011, 02:17 PM
jaksdad66's Avatar
jaksdad66 jaksdad66 is offline
Re: Engine Code P-1345
You need a scan tool that displays cam retard offset to properly adjust the rotation of the distributor. P1345 comes up when it is off by more than 2 degrees i believe.
Old 07-06-2011, 09:36 PM
old_master's Avatar
Advisor/Moderator
P1345 will set if cam/crank correlation is off approximately 25 degrees or more. There are 13 teeth on the distributor drive gear, each tooth represents ~27.69 degrees. If the distributor is installed one tooth off in either direction, the DTC will set. As mentioned, a scan tool capable of accessing camshaft retard is necessary for fine tuning the distributor. Spec is zero degrees plus or minus 2 degrees.
You have to know how it works,
to figure out why it doesn't.
service engine soon ===engine code P0171 Mram76 Off-Topic 2 12-01-2012 06:20 PM
L59 Z engine code and LM7 T engine code......difference????? wirles Silverado 5 10-04-2010 03:14 PM
trouble codes danielgast46 F Series 6 04-06-2009 07:06 AM
99 blaz code 300,1345, 341 brocsbar Problem Diagnosis 2 11-17-2006 03:00 PM
Need Help W/ Engine Code...Got Code, Don't know where or how to fix it vapapichul0 Metro 8 09-13-2005 10:47 PM
