Old 07-05-2011, 06:45 AM
ditdit ditdit is offline
2000 se taurus wagon
2000 Taurus se Wagon
was running, turn off engine went into house came out would not start, after spraying starting fluid in breather housing started up drove home, next day would not start sprayed starting fluid again in breather housing it starts and runs you can shutoff and restart after sitting all night you have to repeat process please help?
Old 07-05-2011, 07:45 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 2000 se taurus wagon
Welcome to the forum!
I'd suggest you start by performing a tune, and make sure the tune up includes a fuel filter. Ideally, you'll want to buy/borrow a fuel pressure gauge and test the fuel pressure at the fuel rail before changing the fuel filter and afterwards. If the fuel pressure is still low afterwards (or you still need to add some spray to get it started), you're probably dealing with a fuel pump that is failing.
Using a fuel pressure gauge though to see if the fuel pressure drops quickly after turning the engine off would help you determine if the likely issue fuel pressure, and if so, if it's related to fuel injectors, fuel pressure regulator, or fuel pump. Without understanding that, you could find yourself replacing parts that are not actually bad.
Does the engine run smoothly and have plenty of power once you get it started?
-Rod
Old 07-05-2011, 06:52 PM
yes rod it seems to run ok after you use the starting fluid ill try ur advice and get back thanks!
1997 Taurus wagon -alternator? Greeneyes_2006 Taurus | Taurus Wagon 6 04-12-2010 01:41 PM
2000 taurus wagon cabin filter + sparkplugs raybuick Taurus | Taurus Wagon 3 07-09-2008 08:39 PM
2000 Taurus Wagon not starting Mr.BarryG Taurus | Taurus Wagon 1 11-24-2007 02:02 PM
2000 Taurus Wagon Engine Swap CableMonkey Taurus | Taurus Wagon 9 04-06-2007 07:39 PM
2000 taurus wagon bubbles in the coolant bottle. yardmechanic Taurus | Taurus Wagon 5 09-11-2006 10:00 PM
