Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 07-04-2011, 06:45 PM
Slickedout Slickedout is offline
Battery keeps drainng
My battery 01 tahoe lt drains none of the gauges work heard about RDO amp fuse how can I fix overall problem
Old 07-05-2011, 08:18 PM
j cAT j cAT is offline
Re: Battery keeps drainng
could be many things. one item that does it is a bad alternator diode...
when you shut down the vehicle remove the alternator wire... disconnect the battery first... then after the alt wire is removed and taped reconnect the battery ..see if the problem is still there...
another method would be to shut down the vehicle, remove the negative battery wire and then place an ampmeter in series with the battery neg connection and the battery negative wire..if you see a current flow of more than 100ma start removing fuses until it stops..also this should be done with the alternator output wire removed to see if that is drawing the battery current down..
Old 07-06-2011, 06:23 PM
mishalah's Avatar
mishalah mishalah is offline
I had the same problem with my '96 burb...couldn't find anything wrong for weeks. Finally, when it was dark I noticed a little bit of light coming from the passenger side visor mirror. The lid was closed but ther little button wasn't fully depressed. After trying a bunch of "fixes" that didn't work I removed the bulb (actually crushed it trying to get it out of the holder).
Old 07-06-2011, 08:12 PM
danielsatur danielsatur is offline
You can use an Amp meter connected with the battery with the ignition key off, than isolate fuse's until no amps are being drawn.
95 Jeep Grand Cherokee Radio Fuse Keeps Blowing - Dead Battery ajcool Grand Cherokee | Grand Cherokee SRT8 1 04-25-2010 10:30 PM
98 Cabrio battery keeps dying. New battery and Alternator OK. WHAT IS IT????? chubbygoatboy Cabrio 1 05-30-2008 11:58 AM
Replaced alternator but new battery keeps going dead! krazidame7 Lumina 4 05-10-2004 09:11 PM
99 Lumina battery keeps dying ChevyLum1 Lumina 4 01-15-2004 11:17 PM
battery keeps dieing? (not thye altanator)I had a h22a racebynow Accord/TSX/Accord Hybrid 7 09-19-2003 07:38 PM
