Go Back   Automotive Forums Car Chat > Toyota > Solara
Old 07-04-2011, 10:05 AM
EZpumpkin EZpumpkin is offline
clearing P0446
It was getting harder to fill up with gas and then the check engine light came on. Trip to the mechanic. "I checked everything. All is clear, your good to go. If it comes back on, let me know." He's a good mechanic, so off I went. It came back on. I realized there was no 'whoosh' when I took the cap off to get gas so I bought a new gas cap. Not the problem. Now it was almost impossible to fuel up. Google gave me some education and I found the charcoal filter and looked in the bottom vent hose. There was a cocoon blocking it at the end. I removed it with a pencil and got gas immediately. I finally could fill the tank. Many starts and miles later the light was still on so I went to Autozone. Code P0446. I read an on line post “P0446 – This indicates there is a restriction or blockage of the Vent Solenoid. This is a TYPE B code. Any thing that prevents the venting of the EVAP system will set this code…usually dust and debris in the Vent solenoid or a damaged vent hose will cause this.” The 'obstruction' seemed to fit as a solution. Question is, how long will it take to cycle out to get the light off? It's been one week already.
Old 07-04-2011, 12:36 PM
danielsatur danielsatur is offline
Re: clearing P0446
Do a Google ''<make> <model> drive cycle''
Example-
X miles of city driving
X miles of Highway driving
Old 07-21-2011, 06:30 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: clearing P0446
Pull the fuse for the ECM and reset it. If it is still a problem, it will return.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Decals - Clear coat & Sanding grit Zman007 Auto Collision Network 1 12-24-2010 07:52 AM
sanding base for clear? Swansen Auto Collision Network 7 07-22-2009 11:31 AM
Code P0446? jpollina64 Blazer 0 05-08-2004 03:45 PM
Check Engine Codes P0441 & P0446 thun Tacoma 0 02-02-2004 03:07 PM
P0446 Code gtcali C/K 1 12-03-2003 05:38 PM
