Old 07-02-2011, 01:45 PM
Shadow Spirit Shadow Spirit is offline
Power Windows
I have a 95 Buick LeSabre and the power windows quit working.I tried replacing the circuit breaker and still won't do anything.I thought maybe it was a bad fuse but I can not find a fuse for it.Sometimes when you let the car sit awhile they would inch a little at a time.Is there a fuse or a relay and where are they located.Thanks for any help.
Old 07-02-2011, 02:43 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Power Windows
The symptoms you have described are a clear indication that the motor is going defunct, replace the motor.
Old 07-02-2011, 03:05 PM
Re: Power Windows
All 4 windows?????????
Old 07-02-2011, 10:20 PM
HotZ28's Avatar
AF Moderator Elite
Re: Power Windows
Sorry, but you did mention in the first post that the problem was with "all 4 windows". If it is that severe, you may have a corroded ground terminal problem under the drivers side carpet near the kick panel. Have you had moist, or wet carpet in the past (or present)? BTW, do the individual door window switches work, or are all of them giving the same problem?
Old 07-03-2011, 04:18 PM
Re: Power Windows
All the windows have the same problem.When we first bought the car the carpet was wet in the back floorboard and had water standing in the spare tire area.I pulled the circuit breaker because it was getting hot.
Old 07-04-2011, 11:27 AM
HotZ28's Avatar
AF Moderator Elite
Re: Power Windows
Click Here & check this ground terminal for corrision.
Old 07-04-2011, 02:29 PM
Re: Power Windows
Where exactly is this connector at?Is this the one that is under the carpet by the kick panel?
Old 07-04-2011, 08:50 PM
HotZ28's Avatar
AF Moderator Elite
Re: Power Windows
Location varies depending on the year. Remove the door sill & look under the carpet. The connector will have either all black wires, or all white wires.
Old 07-04-2011, 09:09 PM
Re: Power Windows
It is a 95.Also thanks for the help
Old 07-05-2011, 10:51 AM
HotZ28's Avatar
AF Moderator Elite
Re: Power Windows
Circuit breakers in the fuse panel protect the power windows & other power accessories, rather than using a fuse. The circuit breaker will open and close, protecting the circuit until the problem is fixed. In addition, if the circuit breaker overheats, that is a clear indication that there is a high resistance somewhere in the terminals/wiring. BTW, be sure to check the circuit breaker (female) terminals in the fuse panel for corrosion, or distortion due to overheating.
'95 Passat FL power window problem frescoraja '93 - '96 1 06-19-2010 01:44 PM
power windows stopped working - 2002 Mercury Mountaineer hoehring Mountaineer 2 01-18-2010 09:25 AM
Power Windows Elec Prob. Please help!! dlane85 Corsica 1 07-29-2009 10:37 PM
`99 Power Window Problem.. beadlingi Prism 0 04-27-2009 06:13 PM
98 power window express down problem fliplover Monte Carlo 1 04-03-2009 11:48 AM
