Old 06-29-2011, 02:18 PM
Disca92's Avatar
Disca92 Disca92 is offline
Harley Davidson FLH Classic
Hi everybody..
i'm working on an old Academy kit found in a little suburbs workshop..
the kit is not as perfect as a tamiya one but although it is 20 years old, the detail is remarkable.
i started with the mythical engine, working around the cooling fins of the cylinders, cutting off the mould lines and improving the detail.
Also I scratched two new collectors changing the position and the angulation.
Old 06-29-2011, 04:16 PM
Disca92's Avatar
Re: Harley Davidson FLH Classic
then i started the frame.. i've assembled every single part and added the rivets on the heads of the engine. rivets has benn obtained by means of nails turned on my dremel and engraved superficially to reproducing the screws.
Old 06-30-2011, 01:12 AM
Disca92's Avatar
BEFORE
AFTER
CARBURETOR
BEFORE
AFTER
SCRATCHBUILT FILTER
It should became like this
Old 07-05-2011, 02:26 PM
Disca92's Avatar
Old 07-05-2011, 03:52 PM
Disca92's Avatar
Old 07-07-2011, 07:58 AM
Disca92's Avatar
so I scratchbuilt a pair of rear shock absorbers by means of brass, plasticard and a steel wire.
I also post the photo of the project paper
Old 07-07-2011, 08:01 AM
Disca92's Avatar
Old 07-07-2011, 08:15 AM
Disca92's Avatar
I then heavily modified the seat by means of two-component filler and plasticard.
after i scratchbuilt the exhaust system using a 4mm tube of plasticard and a flame.
i think to realise a cannon silencer and not a "fish tail" silencer such as the original, so i'll do a customization of the model..but it is worth it
Old 07-08-2011, 07:08 AM
Disca92's Avatar
The last modified parts are the silencers, scratched with a 9mm tube of brass cutted at 45° using my friend "Dremel"
Old 07-08-2011, 01:51 PM
M.Boy's Avatar
M.Boy M.Boy is offline
Nice job!
Exhaust looks great!
WIP: Custom CUb F100 Ducati 916 STUNT YAMAHA
GALLERY: VW Ducati 916 Custom CUb
Mark
Porsche 935 Tamiya 1/12 with Scale Motorsport Super Detail Kit FOR SALE
Old 07-11-2011, 01:05 AM
sportracer02's Avatar
Interesting project !!
Micha
Old 07-11-2011, 07:30 AM
Disca92's Avatar
Thanks everybody!
I spent these days painting the frame, the swingarm, the engine and the wheels.
I used Acrylic black color, MM Metalizer Magnesium and Alclad Chrome.
Instead for wheels I used a drawing tool for masking the tyres and I spayed acrylic white, creating the white stripes..
Disca92's Avatar
Old 07-11-2011, 03:13 PM
Disca92's Avatar
i spent last afternoon to scratchbuild a couple of new brake-clutch lever using two squares of plasticard and two photos of the levers.
i glued the scaled photos on plasticard and I started to cut the excess of plasticard.
then i've finished with files and sand paper.
the last passage is the munting on the handle-bar by means of a 0.7mm steel wire.
So the levers are functioning, but i must find the method to permit the auto-return of the levers-self.
Old 07-12-2011, 02:22 PM
Disca92's Avatar
after the levers, i modified the oil serb and the battery with his chromed-cover.
the parts of the kit were too different from the original bike.
I re-shaped the serb and scratch the battery (which can't see at the finish) and I painted them with gloss black.
So i masked and sprayed the alclad chrome reproducing the shine effect
I also added some cables on the two parts to improving the detail of the entire bike.
I've also done the brake calipers, painted with MM metalizer.
FLH Classic 1/6 dekbamodel Completed Projects / Gallery 4 05-24-2008 07:48 AM
help harley davidson supercharged F150 tupac Street Racing 18 07-19-2004 08:21 PM
help harley davidson supercharged queston? tupac F Series 1 07-18-2004 01:28 PM
Harley Davidson VRSCA V-Rod JDM_USA Street Bikes 19 02-19-2004 11:23 PM
F-150 Harley Davidson front end swap? Bocho22 Expedition 1 01-19-2004 09:23 PM
