Old 06-27-2011, 04:19 PM
cJzBuIcK1014 cJzBuIcK1014 is offline
97 lesabre need some help, CEL on
i have a 97 buick lesabre i have a po171 code its system too lean (bank 1). i checked the air filter and its clean and pretty much new.. i sparyed some air intake cleaner in the throttle body and got no result. anybody have a idea where i shud start looking.... ive got till the end of this month to get it inspected so i cud use ne ideas fast. thanks.
Old 06-27-2011, 06:36 PM
maxwedge maxwedge is offline
A990 racer
Re: 97 lesabre need some help, CEL on
Dirty injectors, low fuel pressure, any leak behind the maf, recently replaced pcv with the o ring missing, dirty fuel filter, are some possibilities. I assume it runs ok?
Old 06-27-2011, 10:55 PM
enslow enslow is offline
Contaminated MAF sensors can also cause lean conditions. Cleaning the MAF sensor requires removing it and cleaning with an appropriate cleaner.
Old 06-28-2011, 09:57 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
"Appropriate cleaner" means; do not use brake cleaner, or carb cleaner on the MAF!
91' LeSabre needing some TLC Loekee75 LeSabre 2 05-09-2006 03:34 PM
92 Lesabre-need Some Good Advice! JESSICAR LeSabre 1 08-26-2004 08:09 PM
Need some help findin some parts. slammina98blazer Blazer 5 03-02-2004 08:03 AM
Need some help from some one that can make custom PE parts. Jon MW Car Modeling 1 10-20-2003 10:33 AM
i need some help on some rims jays87 Tires and Wheels 10 05-07-2002 11:32 AM
