Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-26-2011, 09:03 PM
Picd92 Picd92 is offline
Question Rochester QuadraJet 4bbl adjustment
So I made a mistake and tried to fine tune my quadrajet 4bbl electric choke carb by turning in air bleed valve on the top middle of the carb that already had the cover removed by the previous owner . I turned in the screw and started to backout when I lost idle and the engine died. Now no matter what I do I cannot get it to start without stomping on the gas. Even after its running if I let off the pedal it dies immediately. Any suggestions on getting this back to spec? Also when I put the ignition key to start without turning engine over the electric choke makes a clicking noise ?? I believe its an e4mc or e carb
NEWBEE
Last edited by Picd92; 06-29-2011 at 12:26 AM. Reason: found additional info to add
TPS adjustment oddity caffeineaholic Caprice 15 03-13-2011 10:41 AM
1986 Suburban with a Computerized Quadrajet? 1993Suburban Suburban 2 05-19-2009 06:13 AM
How to adjust valves? lazerphreak Engineering/ Technical 1 05-08-2009 07:22 PM
J-2 Rochester Tri-Power Ragtop_Renegade Oldsmobile Classics 2 02-13-2009 05:40 PM
rochester quadrajet tacoma man Camaro Discussions 89 01-12-2008 12:27 PM
