Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 06-25-2011, 10:14 AM
Scooter75 Scooter75 is offline
Cool 2004 Corolla AC problem
My compressor wont engage - what's the best way to test for what the problem is? I bought a pressure tester but it's inconclusive because I don't get a reading on it or my 2003 corolla which has a working AC. Is it worth just pumping in some 134 to se if that cures the problem?
Old 06-25-2011, 02:46 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 2004 Corolla AC problem
It is most likely a blown fuse in the clutch actuator circuit.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 06-26-2011, 08:26 AM
OK - Thanks - I know I should have done that but it's so hard to get to - I'll do that next.
I have a 2003 to compare to. Presore gauge on 2003 shows 40 psi - 0 on 2004. I added some to 2003 - but wouldn't go in on 2004. Any suggestions on that.
AND THANKS AGAIN FOR YOUR REPLY!
Old 06-26-2011, 05:01 PM
Brian R.'s Avatar
Resident Chemist
Are you adding the freon as directed by Toyota in the shop manual?
Old 06-27-2011, 09:59 AM
first thanks again for your reply. I do not have a shop manual. I run engine with AC on max windows open for 5 minutes. on 2003 can gets REAL COLD AS FREON GOES INTO LOW PRESURE FITTING - BUT NOTHING HAPPENS WHEN i DO THE SAME THING ON MY 2004. ???
Old 06-27-2011, 12:54 PM
Brian R.'s Avatar
Resident Chemist
Is your ac compressor on the 2004 turning? Does freon go into the system (hiss?) - does the freon can get cold? If the compressor turns, what does the sight glass look like?
Old 06-27-2011, 02:07 PM
Thanks again for your reply. The compressor pulley turns but clutch does not engage. Can't add Freon. There is no hissing sound and can is warm. Not familiar with the sight glass - also will try to locate the low pressure cut off switch.
Old 07-11-2011, 09:08 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
A low pressure switch will prevent the clutch from engaging if there is too little freon. If you don't have a gauge set, add a can and see if it kicks in. If so, it was low on freon and you likely have a leak somewhere. Some cans even have a gauge on them. They're crude but will tell you if you're too low.
If it is low but not zero, add a can of freon with leak detection dye. Go for a week then follow the plumbing to find where the dye leaks out. If it is zero, then the system has likely been contaminated with outside air and must be pumped down first with a vacuum pump before adding freon/dye.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
2004 Corolla A/C problem Riche Corolla/Matrix/Voltz 2 04-10-2007 10:52 PM
2004 Corolla Dash Removal boone82 Corolla/Matrix/Voltz 8 11-01-2004 06:14 PM
2004 Corolla Seats UNCOMFORTABLE galbak1 Corolla/Matrix/Voltz 1 05-06-2004 07:54 PM
New 2004 Corolla S; any suggestions? mr_wizzdumb Corolla/Matrix/Voltz 2 02-27-2004 11:26 PM
2004 corolla keyless entry programing Albertaal Corolla/Matrix/Voltz 0 08-31-2003 11:41 AM
