Old 06-24-2011, 11:15 PM
Greg5150 Greg5150 is offline
Howl / Moaning under hard acceleration - 1997 Park Ave
Ok, here is the problem: Under hard acceleration in 1st gear my 97 PA emits a what I can only describe as a howling or moaning noise the kind of reverberates througout the passenger compartment. When the noise is present I can also feel a slight vibration. The noise does not happen when (1) the car is in park and the engine is revved (2) in 2nd or third gear, or (3) under light to moderate acceleration. I checked the engine and trans mounts and the look fine. I checked the exhaust system and all the hangers and they look fine.
I searched the internet and found that someone has a similar problem with a I think a Buick Century and after much diagnosis, the cause of the problem was found to be a bad passenger side inner CV joint. One of the needle bearing clusters was bad.
Any input on this situation would be appreciated. The car has 156k miles on it and has served me well over the years. Thanks
Old 06-25-2011, 10:27 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Howl / Moaning under hard acceleration - 1997 Park Ave
Have you ever replaced the front hub bearings? You can check for play in the bearings by lifting the tire off the ground and gripping the tire @ 6 o'clock & 12 o'clock & rock back & forth. Any free movement/play would indicate the need for replacement. As mentioned, the CV joint could also be the culprit, but check the hubs first.
Old 06-25-2011, 03:24 PM
Thanks for the advice. I checked both wheels like you said and the passenger side has no play but the drivers side definitely has play. I'm going to buy a new hub and I hope this solves the noise issue. I'll keep you updated. Thanks again.
Old 06-25-2011, 09:46 PM
HotZ28's Avatar
AF Moderator Elite
Change both at the same time, you be glad you did.
'95 Park Ave OBDI port location? GMLoyalist Park Avenue 2 04-14-2009 12:57 AM
1998 Buick Park Avenue Ultra shudder under hard acceleration the_doctor Park Avenue 2 10-01-2008 07:48 AM
1997 Park Ave Radio Removal autodoit Park Avenue 8 01-14-2008 09:10 AM
Lookin for a owners and shop manual for a 1997 park ave hosinfefer Park Avenue 8 06-05-2004 10:49 AM
1997 Park Ave Ultra -No Brake Lights belair56 Park Avenue 1 03-12-2004 06:49 AM
