Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 06-24-2011, 06:19 PM
rawoody rawoody is offline
1990 olds 98 hard brake pedal
I have a 1990 Olds 98 4 door that has a herd brake pedal. The brakes were checked and they are fine. Can anyone help
Old 06-24-2011, 06:44 PM
maxwedge maxwedge is online now
A990 racer
Re: 1990 olds 98 hard brake pedal
Short on info, who checked the brakes for this problem, dud they check for vaccum to the p/b booster or the booster itself, usual suspect for a hard pedal, I assume it also does not stop?
Old 06-24-2011, 06:46 PM
Scotty89's Avatar
Scotty89 Scotty89 is offline
I'd check your brake booster and make sure you have vacuum to it.
Old 09-22-2012, 05:02 AM
L78MARK's Avatar
L78MARK L78MARK is offline
Does your car have Anti-Lock brakes? If so it has a Teves ABS system. Usually they will start to fade and give you some kind of warning that the pump is going bad. If it just went bad overnight my guess would be the ABS Pump relay which is located on the firewall on the drivers side next to the ABS unit. Use a Known good relay and swap it out. The Teves ABS systems and parts are expensive so it will get costly if you just start replacing parts so find someone experienced with the correct tools to work on it.
Good Luck
Mark
Hard brake pedal,hissing sound, rpm drop.... gunhound Blazer 21 07-07-2015 09:19 PM
Antilock brake light and rock hard brake pedal fierobert Thunderbird 3 01-19-2011 07:45 PM
brake problem, VERY hard brake pedal but VERY little braking power 95GMCJimmySLE Problem Diagnosis 23 10-24-2009 02:41 PM
Brake pedal does not return bhw33191 Caprice 8 08-29-2009 10:06 PM
