Old 06-23-2011, 07:14 PM
CHEVY1 CHEVY1 is offline
Question 1997 grand prix fog or smoke like through vent of air condioning
Hello
well now I am having like fog or steam like coming through center vents. seems i have air on
run 25 miles then shut air off and notice this pouring out of vent. i put window down or turn air back on and it seems to increase. Temp outside has been humid , but today was in the 70's and air on Max low speed. Something i should be concerned about? or be breathing? air is cold no noises or smells
thanks to all who may some input and help in this matter. I have a few more issues , but
want to post one at a time as i fix
thanks
Old 06-24-2011, 10:13 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 1997 grand prix fog or smoke like through vent of air condioning
I wouldn't be too concerned it isn't harmful. I would however check to make sure that the drain is open. It is located on the firewall just behind the engine. There may be an L shaped rubber hose over the opening. The condensation may be building up in the bottom of the duct work causing the problem especially if the drain is blocked.
Old 06-24-2011, 01:30 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
With the a/c set on max, it's recirculating the interior air rather than drawing in fresh outside air. This can cause a buildup of humidity which would cause this fog/mist. The fog/mist doesn't have a smell to it does it, either sharp/sour or sweet/maple syrup like ? Sour would indicate a freon leak from the evap core, sweet would indicate a coolant leak from the heater core.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
1997-2003 Grand Prix Fog Light Switch LED Conversion tblake Tips and Maintenance 9 01-23-2011 07:25 PM
99 Grand Prix acceleration problems MConder Grand Prix 7 12-11-2010 10:08 PM
1990 Grand prix le problem Erik23512 Grand Prix 1 11-05-2010 12:14 PM
1997 grand prix anti-theft system components Konstantin Grand Prix 8 10-13-2010 10:20 AM
98 Grand Prix Wont Start, need help ASAP! atdudonis Grand Prix 3 06-17-2010 08:57 AM
