Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 06-23-2011, 10:02 AM
kev62 kev62 is offline
Ignition code?
Going to install another Ignition switch with keylock cylinder and key in my 2000 Impala. Will i need to visit my Chevrolet dealer to use a code of some sort to make it work?
Thanks!
Old 06-23-2011, 11:32 AM
j cAT j cAT is offline
Re: Ignition code?
Thanks!
go to a lock smith first to resolve your issue. much cheaper and great knowledge about this.
Old 06-23-2011, 02:53 PM
GMCustomerService's Avatar
GMCustomerService GMCustomerService is offline
Re: Ignition code?
I would recommend contacting your local dealership for more information. They should be able to provide you with the information you are seeking. Please feel free to keep me posted. Thank you.
Tricia, GM Customer Service.
Old 09-02-2011, 08:05 AM
Kev48 Kev48 is offline
Re: Ignition code?
Removed trim on dash and removed Ignition Switch/ Cylinder then unplugged everything and plugged it all back in. Drove around for about a week. No problems. I intalled all back in the dash again. Tightened the two bolts holding the Ignition in place. So far all is working as it should.
Old 09-03-2011, 08:34 AM
Re: Ignition code?
what was the issue with your igntion switch ? was this a key cylinder issue ?
you disassembled and re-installed the same parts ?
Old 09-11-2011, 08:34 PM
Re: Ignition code?
I didn't actually disasemble the Cylinder itself, but i did notice that 1 or both of the ignition mounting bolts were loose. The problem i had was that after i started the car, the heater fan would not work, the de-fogger switch and the electronic readout of the temperature, compass etc, overhead wouldn't work until i struck the key. Didn't install any new parts, or any other second-hand parts.
Old 09-12-2011, 06:45 AM
Re: Ignition code?
if the ignition SWITCH WAS loose then this would explain what occured..
thanks for posting the work done...others may have this condition ..
Ignition Coils on C280 andante147 C-Class 1 06-05-2009 04:57 PM
2000 m/c ss ignition control module problems ABADTAZ Monte Carlo 1 05-03-2009 02:53 AM
1973 el camino- electronic ignition. HELP Landmeier El Camino 3 04-14-2009 08:33 PM
Ignition Lock Cylinder & Worn Keys... Intuit Escort 2 02-18-2009 09:51 AM
93 Geo Prizm M/T 1.8 ignition code oville-rider Nova | Prizm | Spectrum | Sprint 0 11-10-2007 08:29 PM
