Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 06-22-2011, 09:06 PM
rocha155 rocha155 is offline
Passat 01 1.8L turbo check engine code P0118
code P0118 came on. changed out thermastat and coolant sensor next to radiator. total $280 and light was off for 1 month. Wasnt till I changed out crankshaft speed sensor that the light completly shut off. Mechanic said my clutch fan was spinning slow and I saw him stop it with his hand while engine was running. said that I needed to change that out for the light to shut off, but have been driving for 3 weeks now and light is still off. Part is $200 at dealer and 1.5 hours of labor if I do it, but since light is off did not replace. Now I have a low oil pressure warning, replaced oil pressure switch and warning light still comes on
1991 Buick Regal Custom 2 Door 3.8L V6 Check Engine Code 43 Problem Andy1416 Regal 2 05-20-2011 10:41 PM
96 Eclipse rs 2.0 non turbo Check Engine light donidavis Eclipse Problem Diagnosis 6 12-02-2010 08:39 AM
2000 passat 1.8l turbo RCAID99 Passat 0 11-02-2008 10:39 PM
1998 passat 1.8L turbo TEMPERATURE WARNING LIGHT obrut Passat 1 02-18-2007 10:04 PM
2004 passat 1.8L Turbo Air filter change procedure valpon Passat 0 12-11-2005 08:16 PM
