Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 06-22-2011, 05:32 PM
DJ Mista EM DJ Mista EM is offline
1994 lx need new radiator and brakes
My car needs a new radiator and brakes...How do I know which are the best kind to buy? I want it to have a nice warranty and less long
I have a V8 engine
Thanks
Old 06-23-2011, 05:14 AM
kevinande's Avatar
kevinande kevinande is offline
Re: 1994 lx need new radiator and brakes
Well first off be aware that brakes are a "wear" item. meaning they were designed to wear out and be replaced at certain intervals depending on usage. If you do a ton of city driving you are going to wear them faster than highway driving. You should have a selection of pad material from Organic to Ceramic. Stock that car is equipped with I Think 10.5 or 11 inch rotors and it weighs in at round 3800 lbs which is a pretty chubby car. If you do not do a lot of panic stops or riding the brakes often, you can use an Organic pad. Drawback is they tend to squeal and produce that lovely dust all over the wheels people love so much. Semi metallic are good brakes, but since the friction material is harder it has a tendency to be rougher on the rotors. Ceramics are a good option if you tend to use your brakes a lot. They do not stop as well when they are cold. I have seen many people complain that their cars do not stop well when they put Ceramic pad material on their car. All that said if you get your brakes too hot, that is not good either. So choose which material is best for you and go with it. I would not be concerned with a warranty on an item that is designed to wear out. I have a Mark Viii which is your cars cousin, and I upgraded to 13" rotors and dual piston calipers because the stock system was inadequate IMO.
As for the radiator IMO they were designed to fail. Most manufacturers use plastic tanks which over time just fail. It really does not matter where you get it from, if you keep the vehicle long enough, it will fail again. I have three vehicles, and I have replaced radiators on all of them. Two for failed plastic tanks. Any reputable radiator shop should be able to help you out.
Transmission fluid in radiator and brake light STILL on! mimzie Caravan | Voyager 8 05-07-2010 08:35 PM
Need new radiator...Suggestions? KillerKeller_jr Aurora 2 10-10-2006 04:27 PM
new rotors and brakes, new clunking sound? chevyguy93 Cavalier 5 09-15-2006 09:29 AM
1994 electrical problems(heater,radiator and engine) b5bus Century 2 12-31-2005 05:04 PM
need new radiator best place?? Leesmack '88 - '91 Civic | CRX | Wagon | Shuttlee 3 05-10-2005 01:29 PM
