Go Back   Automotive Forums Car Chat > Buick > Century
Old 12-31-2005, 05:58 AM
b5bus b5bus is offline
1994 problems (heater,radiator and engine)
Here are the problems I am having with this vehicle. I'll start from about two weeks ago. The only noticeable minor problem was that the heater was not blowing hot air as it is suppose to do. A few days later heater hardly worked at all (blowing cold air most of the time). Now it quickly escalated to now the engine gauge shows it is overheating and when I try to turn the vehicle off when it is running hot it does not shut off. So far it seems to shut off fine if the engine is not overheating. Any help would be greatly appreciated.
Old 12-31-2005, 02:04 PM
pcv pcv is offline
Looks like you may have a coolant leak. Check the radiator to see if it is full when cold. At this rate, the leak should be obvious. Look around the waterpump, intake and heater hose that goes into the intake at the front of the engine.
Good Luck.
NOTHING LIKE AN OLD CAR.
Old 12-31-2005, 05:04 PM
Re: 1994 electrical problems(heater,radiator and engine)
Good Luck.
Thank you. I know you are right.
