Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 06-21-2011, 06:17 PM
Silver Blue '97 Silver Blue '97 is offline
knock sensor
Can someone tell me where the knock sensor is located on my 1997 Aurora. what does it do?
Thanks in advance.
Old 06-21-2011, 06:32 PM
papa_cadillac papa_cadillac is offline
Re: knock sensor
According to the service book,"The knock sensor is located under the intake manifold, near the starter motor. The knock sensor detects abnormal vibration(spark knock or detonation) in the engine. The sensor produces an alternationg current(AC) voltage which increases with the severity of the knock. The knock sensor is specifically tuned to the engine based on the frequency of vibration that the engine creates when it knocks. The knock sensor for the 4.6 Northstar is tuned to 7000 hertz. This signal is an input to the PCM, which then adjusts spark advance to reduce the spark knock."
Basically, it works in concert with a few other sensors to help the PCM adjust the timing.
Hope this sheds a little light...
Old 06-25-2011, 05:19 PM
Re: knock sensor
To papa_cadillac, thank you for the detailed description.
Replacing Evap. canister Control Valve, Boost Sensor, and Knock Sensor? raja Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 16 06-04-2007 03:25 AM
Crazy knock in 3rd, o2 sensor or knock sensor bad? nates6969 Eclipse Problem Diagnosis 16 06-23-2006 09:11 AM
Knock Sensor and ECT Sensor snizzugglesmaxima Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 10-05-2004 06:53 PM
2000 Yukon How to Replace Fuel Sensor & Knock Sensor mrchiqui Yukon 0 06-24-2004 05:55 PM
Knock sensor and O2 sensor jmmax Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 02-24-2004 11:51 AM
