Go Back   Automotive Forums Car Chat > Ford > Galaxy
Old 06-21-2011, 04:31 PM
ford59galaxie ford59galaxie is offline
Electrical issues
I need help tryin to steady the voltage. Its a 59 ford galaxie and it is running very unsteady. The dome light flashes the head lights flash the radio pops. It seems to be a ground issue but i have a ground from the engine to the body and i have ran grounds from the engine to the frame and even from the negative battery terminal to body/frame and it makes no difference so maybe not a ground issue. I have wired the radio straight off the battery and it still pops and i know the radio is good and it works fine when the engine is not running. I have ran the car with the generator belt off with no difference so it isnt the generator. I have 2 condensers on the voltage regulator and they make no difference. I replaced plugs, wires, cap, points and condensor. There is also a small miss in the engine and 2 cylinders only have about 60 lbs pressure but it is a 292 and people claim valves cannot get tstuck on these. Any ideas what else i could try give me any ideas.
01 Jimmy 4WD Strange Electrical Issue chobes Problem Diagnosis 3 12-29-2010 11:55 AM
New electrical issue Malacite69 Cavalier Problem Diagnosis 0 03-09-2010 02:33 PM
2001 ZR2 electrical issue airboss20 Problem Diagnosis 4 12-26-2009 07:59 PM
1998 Passat Electrical Issues mns247365 '97+ 2 05-22-2009 12:36 PM
2001 cav electrical issues Raeven Cavalier Problem Diagnosis 0 04-29-2009 09:23 AM
