Old 12-27-2010, 09:52 AM
chobes chobes is offline
01 Jimmy 4WD Strange Electrical Issue
My 01 Jimmy has a strange electrical issue. The other day the blower motor on the HVAC would not work. Then it just turned on while driving.
Last night my wife was driving home and the wipers didn't work. She tried to clean the windshield and the washer fluid sprayed the window, but no wipers. Had to pullover at gas station and squeegee the window.
This morning I went out to check if the James was still having the issue and it was (no wipers or blower on HVAC), I pull cover off electrical distribution box, checked fuses and relays and tapped on a few, and all seemed fine, but still no wipers or Blower. Checked fuses in the dash and all were good. So i was thinking what else to check then i heard a click and the blower came on as well as the wipers.
New battery a few months ago. The alternator may be going but put out 14.5V while running. The alternator is getting noisy though. think bearings may be starting to fail.
Here are the issues again:
No wipers
No Blower on HVAC
Flickering head lights and interior lights
Wipers seem to be struggling when they do work. (Slow moving)
Any thoughts would be appreciated.
Hope you all had a Great Holiday.
Old 12-27-2010, 04:01 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 01 Jimmy 4WD Strange Electrical Issue
No wipers
No Blower on HVAC
Check all 12 volt power feeds and grounds.
When checking fuses check for 12 volts on both sides.
Check alt output voltage and amps.
MT
Old 12-29-2010, 11:45 AM
Thanks MT-2500
It was the ground connection on the Left side of engine compartment mounted right by the cruise control module. Had a bad connection. Cleaned off terminals and works great now. Even solved my slow moving wiper problem.
Old 12-29-2010, 11:55 AM
MT-2500's Avatar
AF - Advisor
Good find.
You are welcome and thanks for posting back what you found.
As you found grounds are as important as power feed.
When having problems with anything like that I always check both.
Good luck
MT
Tags
blower , electrical , issue , motor , wiper
