Old 06-21-2011, 01:08 PM
imidazol97 imidazol97 is offline
AF -Advisor
Can't grease tie rod end
Grease won't go through the grease fitting on my 98 leSabre. I took off the zerk fitting and grease goes through. But when I put it back on, grease won't go through? I even left it unscrewed half a turn.
Do I just need a new fitting?
Old 06-21-2011, 02:30 PM
enslow enslow is offline
Re: Can't grease tie rod end
I had that happen to a year old tie-rod end. I had to take a toothpick and pick out dried up grease from the ball joint itself, as well as the fitting. I'm not sure why, but it seems to need greasing once every 2-3 months. Other cars I could get away with once every 6 months.
Old 06-21-2011, 09:05 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
In addition, always be sure to wipe the grease fitting totally CLEAN before greasing and don't forget to grease the rear links.
Old 06-21-2011, 09:56 PM
Good catch Hotz28. I do it out of habit I didn't even think to mention it.
Old 06-23-2011, 09:03 AM
AF -Advisor
This tie rod end is on the front. It's been about 6 months since last greasing: car used mostly around the village.
Does something go wrong with zerk fitting that grease would go through when fitting is off the car but won't go through when on the car?
I tried digging into the tie rod end through the opening, and didn't see to have any grease that was dried up.
I am working with the tire on the car, so it's difficult to see.
Old 06-23-2011, 10:24 AM
Here's a thought. First, is the tie rod end the one right up against the disk brake shield? I can't remember exactly which in is in that location. Anyway, how hot does it get sitting a mere millimetres away from the disk brake shield? Is the grease simply getting baked there? I've had the same thing happen on my wife's car. About every 2-3 months it gets noisy and needs more grease. I think I'm going to get some of those angled nipples so I can shoot grease in there without pulling the wheels every time.
Also, I had to use a toothpick and physically press out baked on grease from both the nipple and inside the ball joint. This ball joint was less than a year old before it was doing this.
ball joint or tie-rod end? thinmint Dakota 1 03-07-2010 10:39 PM
how to change tie rods? JohnVT Cirrus 3 04-05-2009 10:32 AM
Help! - I can't get the tie rod end off the shaft. yellowfiero Trans Sport 7 02-16-2009 07:46 AM
front end/brakes/tie rod end? mrferley Escort 2 03-30-2006 10:09 AM
Tie Rod Ends - Add a Grease Zerk? dougand3 Windstar 8 07-03-2005 09:13 PM
Tags
fitting , grease , zerk
