Go Back   Automotive Forums Car Chat > Chrysler > Pacifica
Old 06-19-2011, 09:52 PM
Rizin84 Rizin84 is offline
Exclamation Electrical
I have a 2005 pacifica awd 3.5 dash lights go dim radio speakers crackles with radio off abs light comes on have codes in transmission for battery voltage low and abs code for battery out of range checked charging system seems ok, charging at 14.2v. seems to happen intermittently has had 2 new battery checked battery cables also look ok. Any help is really appreciated.
Old 02-07-2012, 10:41 PM
Re: Electrical
Update seems to be that there was a 2 volt drop between battery cable and terminal. Pcm would notice the difference and ramp up the volatge field on alternator causing weird problems. Ended up replacing the engine harness and that took care of problems.
Old 02-08-2012, 04:44 PM
jamesslcx jamesslcx is offline
Re: Electrical
Rizin84, thanks for sharing this. Good to know.
Electrical Issue - Psgr Door Electr/Keyless Entry BostonAvalanche Tahoe 1 11-15-2007 08:30 AM
Electrical Problem(no electrical responce) 03capricess03 Caprice 4 10-04-2007 01:54 AM
Di-Electric vs Electric Grease hollow1 Engineering/ Technical 3 05-01-2007 11:42 AM
electral probs on a 96 electrical, seats, dash pod Grand Cherokee | Grand Cherokee SRT8 8 12-20-2003 07:17 PM
