Old 06-19-2011, 01:34 PM
valente valente is offline
whats going on with my car
I just got done waxing my car using a porter cable.it took me about 7 hours and after i was done it sat in the garage for a day. now after i went outside and started it,i get this-
traction control off
stability control off
service ABS system
service traction control
service stability control
service variable effort steering
now the steering is a little harder.i unplugged the ground on the battery and left it for about 3-4 minutes but that didnt help.
little help please.thank you
Old 06-19-2011, 07:28 PM
TDWPgtp's Avatar
TDWPgtp TDWPgtp is offline
Re: whats going on with my car
ABS/tire pressure/ whatever else sensor plug probably. theres one on each wheel hub. i assume you have an 04+ because i dont have most of those alerts, so i dont know if im right...but it deffinately sounds like it could be caused by the plug or the wiring thereof.
i suggest takin a look at all of them (one on each wheel, i do believe). maybe try disconnecting and reconnecting them, unless one of them is obviously detached. thats my two cents. good luck, though
The Following User Says Thank You to TDWPgtp For This Useful Post:
valente (06-19-2011)
Old 06-19-2011, 10:02 PM
i have a 2005 gp.i had just washed the car and it sat in the garage for 1 hole day while the floor was still wet.i took the car out and let it sit in the sun for about 2 hours and left the garage door open to,went back in the car,started it,and now is fine.go figure
thanks for the help
Old 06-21-2011, 03:37 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Maybe some water got into one of the contacts around the car, that's why you need to be very careful when pressure washing your car, specially at the engine compartment.
It's good to know the problem is gone!
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Whats going on with my Car? Heather624 626/Capella/Capella Wagon 5 11-30-2008 02:08 PM
Car needs tuning/repair. But whats wrong? Heres whats going on.... alkemist Riviera 5 05-31-2006 05:45 PM
whats going on with my car?? briea '71-'87 Civic | CRX 2 07-13-2004 09:19 PM
what wheels should i go with onesojourner '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 18 05-11-2002 01:38 AM
Does anyone know whats going on with max org.??? Kly-Max-99 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 09-20-2001 09:21 AM
