Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 06-19-2011, 01:38 AM
803ChevyBoy 803ChevyBoy is offline
Angry 90 caprice leaking coolant
Needed another water pump so I get that now it looks like coolant is coming from timing cover area is this possible? Or maybe the water pump gaskets not thick enough enough or something really need caprice up and running .
Old 06-19-2011, 07:13 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 90 caprice leaking coolant
WHAT ENGINE?
Drop some coolant dye in coolant and run and put the light tester on it and find out where the coolant is comeing out.
Also a hand pump up rad pressure tester will put pressure on system and show up leak.
Places to check are hoses and intake gasket and rad and front freeze plugs and water pump gaskets/back cover or weap hole..
With a rad leak coolant can blow back on front of engine.
With a intake gasket leak coolant can run down on timing cover.
Also can be freeze plugs on front of engine.
Let us know what you find.
MT
Old 06-19-2011, 01:36 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Verify the installation of your water pump. On the Chevrolet engine, there's no water anywhere near the timing cover, outside of the two water pump flanges. If you're seeing water on the timing cover, it's likely a leak in this area, or a lower radiator hose that's spraying water up toward the timing cover.
If you have a wagon, it will have the Olds 307 engine in it, which has a water pump that bolts directly to an alloy timing cover (that also acts as the rear to the water pump). A leaky water pump gasket, in this case, is the likely culprit.
Since you see the leak after you have replaced the pump, I'd look for loose bolts and/or an improperly installed gasket. Also, check the tightness of the clamp on the lower radiator hose. Don't overtighten. On the Chevrolet engine, the passenger side of the block has an extra hole drilled below the lower water pump flange bolt, for coolant bypass purposes. Make sure you have the proper gasket here.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
1994 Olds Achieva, 3.1 S Leaking coolant rastaron Achieva 1 09-23-2010 11:13 AM
3100 v6 leaking coolant from timing chain gasket? jamc204 Grand Prix 4 06-22-2010 10:18 AM
2002 SE leaking coolant jamc204 Grand Prix 2 06-17-2010 08:56 AM
98 Grand Caravan 3.3L Coolant Leak hooperkj Caravan | Voyager 4 04-22-2009 04:17 PM
91 caprice leaking coolant leaking coolant Maticlee Caprice 12 08-20-2008 08:31 AM
