Go Back   Automotive Forums Car Chat > Mazda > 3
Old 06-18-2011, 04:21 PM
somervillearron somervillearron is offline
premacy clutch problem scraping sound
i have a 03 plate mazda premacy 2.0 sport
it has the 5 speed manual and when it is sitting still started you hear a sort of scraping noise coming from the clutch area but when i press the clutch it goes away completely
also though when i change gear it changes smoothly but sounds notchy the clutch and gears feel fine it is not riding on the clutch atall but i know the noise is there and that it may cause me to break down
basicly i think it is the clutch release bearing but i am not sure i would greatly apresiate some help as i dont know what to do i am scared to change the clutch incase thats not the problem
but its like a quiet scraping noise and when the clutch it pressed it goes away and also when driving i dont notice it but it may still be there
also does anyone know how to program the key fob for these cars?
i know this car dosent belong here but the premacy forum looks like nobody goes there
Old 09-10-2011, 04:40 AM
OttawaTech OttawaTech is offline
Re: premacy clutch problem scraping sound
The only way to be a hundred percent is to take it into a shop. That said I'd say 90% if you are stationary and you hear a noise and then you clutch in and it goes away, you need to pull the tranny. Thats likely what I would tell one of my customers.
Old 12-21-2011, 08:30 PM
scott17818 scott17818 is offline
sounds like your clutch release bearing is going... bitch to replace in most FWD cars.. as you have to drop the tranny.. and if your car has any miles on it (more than 100k miles) I recommend spending the extra coin for a factory replacement/OEM clutch.. it's well worth the effort to do both at once, rather than be back in there in a few months.. good luck.
Old 12-23-2011, 07:13 PM
DeltaP DeltaP is offline
Oh definately, I wouldnt go through all that work and not change the clutch and maybe even flywheel unless I had velcro on everything!
2003 Forester transmission/clutch problem? JonnyU Forester 3 07-03-2011 03:49 PM
premacy sport clutch problem somervillearron 5 | Premacy 0 06-18-2011 04:19 PM
03 premacy clutch noise! please help somervillearron Premacy 0 06-18-2011 04:17 PM
clutch problem..i think bov3220 Engine, Transmission and Drivetrain 4 05-22-2009 12:17 PM
Clutch Problem? Swishhh sounds?! Check this 01spyder[GT] Eclipse 2000+ 4 07-21-2004 01:20 PM
