Go Back   Automotive Forums Car Chat > Mazda > General Discussion
Old 06-18-2011, 04:20 PM
somervillearron somervillearron is offline
premacy clutch problem scraping sound
i have a 03 plate mazda premacy 2.0 sport
it has the 5 speed manual and when it is sitting still started you hear a sort of scraping noise coming from the clutch area but when i press the clutch it goes away completely
also though when i change gear it changes smoothly but sounds notchy the clutch and gears feel fine it is not riding on the clutch atall but i know the noise is there and that it may cause me to break down
basicly i think it is the clutch release bearing but i am not sure i would greatly apresiate some help as i dont know what to do i am scared to change the clutch incase thats not the problem
but its like a quiet scraping noise and when the clutch it pressed it goes away and also when driving i dont notice it but it may still be there
also does anyone know how to program the key fob for these cars?
i know this car dosent belong here but the premacy forum looks like nobody goes there
Old 07-04-2011, 05:43 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: premacy clutch problem scraping sound
G'day,
It sounds like your spot on with it being the release bearing.
When worn they often make noise when not under load.
Putting your foot on the clutch pedal loads up the bearing, which makes them go quite again.
This will continue to happen until the bearing becomes so worn it makes more noise under load, or it collapses.
What ever is wrong with it you need to get the gear box off and have a look.
While it's off, replacing the clutch and release bearing is cheap and easy to do.
Not a lot of action in the Premacy forum I'm afraid. They are not often owned by people who are big car enthusiasts.
But then I can't really talk, I'm huge automotive nut, but I drive the second most boring car ever a made, a Honda Accord.
2003 Forester transmission/clutch problem? JonnyU Forester 3 07-03-2011 03:49 PM
premacy sport clutch problem somervillearron 5 | Premacy 0 06-18-2011 04:19 PM
03 premacy clutch noise! please help somervillearron Premacy 0 06-18-2011 04:17 PM
clutch problem..i think bov3220 Engine, Transmission and Drivetrain 4 05-22-2009 12:17 PM
Clutch Problem? Swishhh sounds?! Check this 01spyder[GT] Eclipse 2000+ 4 07-21-2004 01:20 PM
