Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 06-18-2011, 12:29 PM
803ChevyBoy 803ChevyBoy is offline
Unhappy I30 problem
Car cranks up rough idle when out driving car just dies then crank go fo awhile longer then dies again. What sensor would cause this problem I dont know if check engine light indicator is not working but it doesnt come on
Old 06-19-2011, 09:56 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: I30 problem
Model. Mileage. Service History. Happens only Hot/Cold/always?
If u ask which sensor can do such, MAF. Rpm sensor - only paired with bad TPS.
But who says its a sensor issue? Any supply voltage issue - cutoff - can lure behind dying engine. First things first: swap plugs, wires, cap... also Check issues mentioned in linky below.
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 06-19-2011, 11:51 AM
Re: I30 problem
It does it when its hot the car is a 96 infiniti i30 have recently changed plugs and wires changed fuel filter thought that was problem. Air flow assembly looked clean when I disconnected to check it.
Old 06-19-2011, 01:29 PM
Re: I30 problem
It has distributor? Cap crack is typical, smone said third cap from shop was ok...
Test drive with MAF disconnected. Will have 2200 rpm ceiling, but no MAF problems will not be there.
Sometimes the self diag gives error code. Test.
Old 07-11-2011, 07:24 PM
rather_b_boatin rather_b_boatin is offline
Re: I30 problem
Although Nahka is the king of this forum, just wanted to add a MAF can look/appear to be perfect with the eyeball but magic inside may not be happening. (had a bad MAF on my Max) If that is the case buy it anywhere but the dealer, they tried marking mine up >$300.. But don't buy junkyard either.
Nissan Cefiro - Idling/driving rpm problem fnasir Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 9 10-01-2010 10:35 AM
01 Silverado Tranfer Problems kash1235 Silverado 0 04-14-2009 05:44 PM
98 pathy fuel gauge problem akaesha Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 03-28-2009 08:35 PM
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
E 150 Starter problem NIck86 Econoline 3 03-12-2009 07:38 AM
