Old 06-18-2011, 10:35 AM
danashort danashort is offline
99 cherokee wants to stall out...
ok here is the problem that I have been facing now for some time...my 99 cherokee when first started will act like its going to stall out w/in the first 5 min of running...it never does though, and it will get a surge where the RPM's go from almost 0 to 6...then it runs fine...you can also hear where there is air being sucked in...now if i'm driving it will act like its going to stall when u come to your first stop, i flutter the gas, but you can hear a loud knocking as the engine is trying to go, then the surge hits and it runs fine....i've replaced fuel pump, try engine cleaners like sea foam and mopor stuff for jeeps..my mechanic thinks its valves sticking...I also at times lose oil pressure for no reason while driving...any help?
Old 06-24-2011, 05:14 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: 99 cherokee wants to stall out...
The first thing I'd check is the plugs, cap, rotor and plug wires. If these are all worn, you could have those issues with a cold engine. Check air filter also. Post back once you've had a look and let us know how it's doing.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 06-25-2011, 06:56 PM
rhandwor rhandwor is offline
I would check with Advanced or Auto Zone and get a manual loaner pressure gauge.
If your losing oil pressure the hydraulic lifters won't work properly.
Have you done regular oil changes? A plugged strainer maybe your problem.
Old 06-28-2011, 10:10 AM
ok i've done the tune up and still the same results...i have done regular oil changes but it does have 150,000+ miles..i'll have someone check into the strainer...
Old 06-28-2011, 12:03 PM
If the test gauge shows you losing oil pressure you have to pull the pan to clean the strainer.
91 Century Stalls Out smilen2894 Century 1 10-01-2010 02:43 PM
94 Mercury Villager Hard start - engine shakes - stalls out runnergirl262 Villager 6 02-12-2010 10:28 PM
98 grand cherokee stalling out and idling rough Tommygunlee Grand Cherokee | Grand Cherokee SRT8 6 01-26-2009 10:09 PM
93 Cherokee tries to stall, but never stalls out completey. Scott814 Cherokee 2 10-29-2004 01:51 PM
88 Cherokee stalls out sporadically EZ1908 Cherokee 3 01-11-2004 05:42 PM
