Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 06-17-2011, 06:48 AM
85mustangGT 85mustangGT is offline
Electric Fan
*99 Bravada*
I am going to add a little 10 in. electric fan in front of the radiator for some extra cooling and I am trying to get a wire from inside at a switch to the engine area.
Has anyone ran wires in a bravada and what is the easiest route to get to the engine area?
Thanks
Old 06-17-2011, 07:53 AM
Scrapper Scrapper is offline
AF Premium User
Re: Electric Fan
Originally Posted by 85mustangGT View Post
*99 Bravada*
Thanks
ok you want to take a test lite and hook into wire so when you turn switch on you can find one that has power to the wire when switch is on. am i taking you rite as i exsplained how to to this?
Old 06-17-2011, 12:34 PM
kevinande's Avatar
kevinande kevinande is offline
Re: Electric Fan
Do you do a lot of idling with the A/C on? If not what exactly is the point of the fan?
Old 06-17-2011, 09:45 PM
Re: Electric Fan
I actually do sit in traffic for about 30 minutes each way to and from work, plus with it being 90 - 100 this time of year it could not hurt to have a little more air flow.
I am looking to get a wire from inside thru the firewall to the engine compartment, has anyone found a simple way to run one?
Old 06-18-2011, 05:03 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Electric Fan
I don't know of an auxiliary fan circuit on a Bravada.
I put all mine in neutral when sitting at a traffic light or stopped traffic during the warm months to keep the oil pressure on the right side of the gauge. It just happens to help the cooling system too.
Old 06-18-2011, 06:36 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
Re: Electric Fan
Adding anything electrical will increase the load on your engine and reduce your gas mileage unless it replaces a mechanical load so I wouldn't recommend adding a fan. There are some electrical fan replacement kits for the Bravada available in the after market, and there was a do it your self replacement post about using a junkyard Taurus electric fan to replace it. Here's a couple of links on the subject.
http://www.automotiveforums.com/vbul...d.php?t=467367
http://www.s10forum.com/forum/f105/e...hreads-402624/
http://www.automotiveforums.com/vbul...ghlight=taurus
The Following User Says Thank You to ericn1300 For This Useful Post:
Chris Stewart (06-20-2011)
electrical problem jamseeb4 F-Body Problem Diagnosis 0 06-11-2011 05:00 PM
Replacing clutch fan with dual electric fans. thebeastjuggalo Performance 11 12-23-2006 02:48 PM
Electric Fan vs. Clutch Fan tass81685 Sierra 1 10-20-2006 08:21 PM
Clutch Fan vs. Electric Fan MeNBabyD Durango 0 12-23-2005 03:22 PM
Would you swap belt driven fan for electric fan? highlandlake Rodeo | Passport | MU 2 01-28-2005 04:34 PM
