Go Back   Automotive Forums Car Chat > Subaru > General Discussion
Old 06-16-2011, 10:11 AM
BillyBoyBliss BillyBoyBliss is offline
Immobiliser not working
I have a 2003 Subaru Heritage Wagon (Liberty body) and the buttons on my key remote lock and immobiliser have stopped working. I changed the battery and checked that it was delivering 3V. Also, I cleaned the small circuit board with alcohol and checked that the contact points were all ok. Fortunately the dealer supplied a spare key when I bought the car and it works just fine, but I'm worried that if the spare also fails I'll be left high and dry. Another thread about a Scenic mentioned about the 4 digit code from the manufacturer to reset the key. I've got my code but I don't think that resetting it will make both keys work. If you have any suggestions regarding repair of the key or advice about a replacement.. I would be much obliged.
BillyBoy
Old 06-17-2011, 09:43 AM
Re: Immobiliser not working
Problem solved. I took the functioning and non-functioning key/remotes to a locksmith. They had a machine to test whether a radio signal was being emitted from the key when the lock/unlock key was pressed. The faulty key wasn't generating a signal. Although I cleaned the terminals on the small chipboard inside the key, the locksmith scraped some more and then the key started working.
97 Breaks not working crackedvenom Taurus | Taurus Wagon 1 05-12-2010 08:17 PM
tcs not working & abs not working either jimhorsefan What do you want to know? 1 01-11-2009 12:19 PM
92 Explorer GUAGES NOT WORKING, 4WD not working rickmosley Explorer | Explorer Sport Trac 3 02-15-2005 06:55 PM
Fan Not Working A/c Fan Works Engine Hot Fan Does Not katrinacat1 Grand Prix 0 02-15-2005 05:50 AM
4X4 control panel lights not working 4 wheel drive not working french69ssrs S-10 1 12-28-2004 04:25 PM
