Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 06-15-2011, 08:11 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
2004 Rear upper control arm
Anyone replaced this item? It's the V shaped piece that is attached to the body and top of the rear axle.
I'm debating whether I can do it without a lift or if a lift is required....looks like a bit of a reach to get to some of the bolts and I don't know if there will be enough room underneath to reach everything. I've got jackstands and that may be the way to go.
I refuse to pay the stealership $700 when the parts can be had for under $200 in the aftermarket.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 07-19-2011, 11:22 PM
mikec041 mikec041 is offline
Re: 2004 Rear upper control arm
It can be done using jack stands on the frame rails. Tight and real PIA but doable. Suggestion remove and install ball joint while control arm is off the Jeep. You will only be able to use a box wrench to remove the 3 bolts holding the ball joint to the axle I'd suggest something like a gearwrench. good luck.
Old 07-19-2011, 11:54 PM
jamx13 jamx13 is offline
Send a message via AIM to jamx13
I pulled my "wishbone" out about 2 yrs ago. It was a bit of a struggle but I did it in my driveway with the Jeep on jackstands & both rear wheels off. I didn't replace the entire wishbone though, I just replaced the bushings & the balljoint - got the parts from Quadratec for about $60. If you replace the entire wishbone & balljoint, you're looking at about $160. Here you go:
http://www.quadratec.com/products/52449_1052.htm
http://www.quadratec.com/products/52088425.htm
http://www.quadratec.com/products/56015_009_07.htm
Old 07-25-2011, 08:52 PM
Thanks guys....I've got the new "wishbone"; found a guy that has a lift so will probably get with him for the repair.
I'm not interested in doing the job in 100* temperatures in the driveway.....
question -- did your handling improve when you replaced the part? I've noticed a bit of (I think) sloppiness in the rear end on the highway.
S13 Rear Upper Control Arms Wanted! under8seconds 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 0 07-21-2005 05:00 PM
-=Rear Upper Control Arm for sale=- publicenemy137 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 10-24-2004 08:53 PM
rear upper control arm Light Show Grand Cherokee | Grand Cherokee SRT8 0 07-25-2004 11:01 AM
Adjustable rear upper control arms Thrill91Si '88 - '91 Civic | CRX | Wagon | Shuttlee 3 05-27-2003 12:40 PM
has anybody had a rear upper control arm break?? velocitySiR '71-'87 Civic | CRX 8 04-25-2002 05:51 PM
