Old 05-27-2003, 11:24 AM
Thrill91Si Thrill91Si is offline
Question Adjustable rear upper control arms
I just bought my 91 Si Hatch a month ago. Before we bought it, we knew the suspension was shot. A couple owners back, the springs were blowtorched in a cheap man's attempt to lower the vehicle. I assume when his/her tires started to shred, they got adjustable rear upper control arms to correct the camber. The last owner didn't want the car as low as it was, so he added spacers in the springs, inconsistantly, 6 spacers in one spring, 1 in another, etc... However, he didn't change the adjustable control arm, so the inside of his tires are being ground away rapidly, as can be seen on the current set of rear tires.
As would be expected, I am doing a suspension overhaul. Urethane bushings and new tokico blue shocks and springs all around.
My question is, what should the rear control arm be set to? The Tokicos are supposed to lower the car 1 1/4". I am planning on taking the car into the Honda dealer for an alignment once I get everything reassembled(shocks haven't arrived yet). Would they correct the upper control arm during the alignment?
Thanks for your help!
Old 05-27-2003, 11:37 AM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: Adjustable rear upper control arms
Whoever does your alignment should adjust it for you.
Old 05-27-2003, 11:57 AM
chopstick1981 chopstick1981 is offline
if the last owner raised the car then the tires should be wearing on the outside. you wear on the inside of the tire when you lower the car. You should also get under there and check whether or not you have a front adjustable camber kit cuz if you dont they cant adjust camber on the front without installing a kit themselves.
Old 05-27-2003, 12:40 PM
Thanks Kris.:flash:
I don't think the front has a camber kit on it chopstick. The front suspension appears stock. I'm not sure why anyone would correct the camber in the rear and not the front. The front tires are new, or else I could tell where it was rubbing.
If the rear arm was adjusted for a lowered car, and then the car was raised, pushing the wheel center away from the arm, wouldn't that pull the top of the wheel in and the bottom of the wheel out? I think that would rub the inside of the tire. Just a newbie thought...no real experience. Its possible the previous owner tried to correct the camber in the rear and went too far.
S13 Rear Upper Control Arms Wanted! under8seconds 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 0 07-21-2005 05:00 PM
-=Rear Upper Control Arm for sale=- publicenemy137 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 10-24-2004 08:53 PM
rear upper control arm Light Show Grand Cherokee | Grand Cherokee SRT8 0 07-25-2004 11:01 AM
Thrust Arm/Upper Control Arm bushings Ben Ferrell 7 Series 0 11-25-2002 06:19 PM
has anybody had a rear upper control arm break?? velocitySiR '71-'87 Civic | CRX 8 04-25-2002 05:51 PM
