Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-15-2011, 07:37 PM
VinceH VinceH is offline
200 Rodeo hard brake pedal
All, it's been awhile since I have had some issue with our 2000 Rodeo until today.
Wife was driving home with the kids and hit the brake pedal and she descibes it as so " hard as concrete and slow to stop". We have no ABS light on or any other warning lights.
Has anyone expierenced this before or might know what could cause this?
Thanks for the help....
Old 06-15-2011, 08:11 PM
Cat Fuzz Cat Fuzz is offline
Re: 200 Rodeo hard brake pedal
I would start by checking the vacuum line to the power brake booster.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Old 06-16-2011, 06:50 PM
all the lines are good, and the vacum holds when I pump the brakes while the engine is off, once I start the engine, the pedel returns to it's normal feel, could it be a sensor?
Old 06-17-2011, 10:01 PM
Re: 2000 Rodeo hard brake pedal
Here is what I have found so far.
Pulling codes:C0281,C0282 & C0276. If anyone has info about these please let me know. I also found that the right rear inner brake pad must be getting hung up, it is worn down to almost nothing while the outer has about 1/3 left on it.
I had Les Schwabb do the rear brakes about 3 years ago(42K miles) and they already need to be replaced. I went 110K miles on the originals! Not too happy about that!
Any info is greatly appriciated.
Thanks
Old 06-24-2011, 10:17 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
Looks like you may need a brake switch and ehcu/abs module
Hard brake pedal,hissing sound, rpm drop.... gunhound Blazer 21 07-07-2015 10:19 PM
Antilock brake light and rock hard brake pedal fierobert Thunderbird 3 01-19-2011 08:45 PM
brake problem, VERY hard brake pedal but VERY little braking power 95GMCJimmySLE Problem Diagnosis 23 10-24-2009 03:41 PM
Brake pedal does not return bhw33191 Caprice 8 08-29-2009 11:06 PM
