2001 Subaru Impreza issue
I had a problem with the CV Axle and the Wheel Bearings. I replaced them already and I ran into another issue with the Wheel Studs and the Ball Joint, so I ended up replacing them as well. Yesterday I put everything back together after replacing all the parts mentioned before and I made sure everything was bolted down and tightened, and then the tire back on and lowered the jack. I started up my car expecting it to drive just fine and it was harder to get into gear than before and it wouldn't move in reverse, neutral, or drive. I called a Monroe Muffler around here and they told me that the CV Joint is probably not seated all the way inside the Transfer Case. So later the same day I took everything back apart and made sure that I put the CV Joint back into the Transfer Case and I put the pin back in and made sure that both CV Axles would turn at the same time, which they did. I figured it was good so I put it all back together again and went through the same process as before, making sure everything was tightened down, all the bolts and nuts and pins were where they needed to be. Everything seemed to be good. I put the tire back on again, lowered the jack, started the car and attempted to drive it again. It still won't move.
Does anybody have any ideas about why this is happening.
