Old 06-14-2011, 10:06 AM
ianpoteet ianpoteet is offline
chevy 1500 4.3 problem
ok if anyone can help me out would be great
i have a 92 chevy 1500 with the 4.3 vortec and its having running issues on idle and while driving it will have a irratic idle and also will sputter if u dont let it warm up before u drive it and it will have a very hard time trying to move as if it was dieing it does this the most when its not warmed up and it runes at like 150 deg ive changed the
IAC
MAP SENSOR
PLUGS
WIRES
CAP
ROTOR
USED 3 CANS OF SEAFOAM TO SEE IF IT WAS CARBON BUILD UP
MY FUEL PUMP SEEMS TO BE WORKING IVE CHANGED MY FUEL FILTER
when i start it up sometimes it will sound like a few cyclinders are not firing ad so ill shut it down again and start it back up and usally it will be fine just with the irractic idle it will also do it in gear and it just doesnt seam to have the power it should
Old 06-15-2011, 07:38 AM
Frankp87 Frankp87 is offline
Re: chevy 1500 4.3 problem
Have you checked the timing?
Frank
1998 Silverado Z71
Old 06-15-2011, 07:48 AM
NHRA's Avatar
NHRA NHRA is offline
check your egr valve
Old 06-15-2011, 09:53 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
IAC
MAP SENSOR
PLUGS
WIRES
CAP
ROTOR
Have you checked for codes?
Any codes or check engine lights on running?
Clear codes and then run and recheck for codes.
Then post back code no.
The only way you can test fuel pump is with a pressure gauge.
Things to check.
Does it have good hot blue spark to all plugs?
Correct firing order on plug wires?
Good comression on all cylinders?
Good AC delco plugs?
Fuel pressure?
Engine vacuum reading with a vacuum gauge?
And as mentioned.
Base time with bypass wire unpluged?
check egr valve for stuck open?
MT
1990 chevy 1500 4.3 issues chevy3223 C/K 0 02-28-2010 05:57 PM
98 2wd 4.3 dual exhaust jesse938 C/K 3 05-17-2009 12:37 PM
91 4.3 Injectors Will Not Pulse chaddeaton Problem Diagnosis 1 03-10-2009 05:33 PM
94 s10 blazer 4.3 high oil pressure chevyshitsonford Problem Diagnosis 4 03-08-2009 09:11 AM
PROBLEM now 98 blazer 4.3 v6 just replaced fuel pump smiley24 Problem Diagnosis 7 02-26-2009 10:45 AM
