Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 06-14-2011, 08:12 AM
KitCarOne KitCarOne is offline
2002 Impala w/police package cant find key fob ecu harness in dash
i am trying to add keyless entry to my detective model Impala. I can not find the harness to plug in the ECU box in the top of the dash. I have felt under the dash to see if i could find the open 4 wire blue connector or harness coming off the BCM (all 3 harnesses are present and plugged in) i cant seem to locate the end of the harness! I removed the crashpad to see if i could locate it from the top, no connector. From my research the harness should be right next to the indent for the ECU location. anyone have any ideas? is the location changed in the police package models?
I have checked for the FOB option when running through the radio diagnostics. no option to program. I know i will have to use the TECH2 once connected.
Old 07-18-2011, 09:30 AM
Master X's Avatar
Master X Master X is offline
Re: 2002 Impala w/police package cant find key fob ecu harness in dash
This should help, from what I understand the BCM needs to be programmed with Remote keyless entry RPO code as well. I'm not sure if that can be done on an already programmed BCM.
i cant find the problem!!!! tomshaze Grand Prix 29 09-08-2010 11:18 AM
'09 altima program key fob jib922 Altima 0 08-26-2010 09:18 AM
Car outlived its Key Fob jmhsrv Odyssey 0 07-03-2010 02:06 AM
2003 Impala - 9C1 Police Package sarotara Impala | Impala SS 1 12-17-2007 04:42 PM
HELP!!!! 2002 Chevy Blazer, need to program the key fob!!! RICHCAMARDA General Discussion 0 12-15-2005 08:21 PM
