Old 06-14-2011, 09:04 AM
thenextyou thenextyou is offline
Transmission Question
Hi I have a 1993 K2500 and the trans went out on it. I want to just put a used transmission in it. Through doing some research it looks like its the 4l60 and it was only the same from 93 to 94 so does that mean I can only use one from a 93 or a 94?
Old 06-15-2011, 08:17 PM
j cAT j cAT is offline
Re: Transmission Question
many different transmission configurations...check that the electrical connectors are the same with the replacement...you must be careful to get the correct one that will work with the computer,...
2500 uses a 4l80 >>>? 1500 has the 4L60 ...
Old 06-21-2011, 01:21 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
If you have the 305 (not likely in a 2500) or 350 V8, then it's probably the 4L60-E...the trannys went electronic in 1993. If it's the 454 or diesel, then likely the 4L80-E.
The 4L60-E came in two versions, one-piece and two-piece housings where the bell and body are either separate or single piece.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 06-26-2011, 01:12 PM
procaddytech procaddytech is offline
Check you RPO code placard in your glovebox. RPO M30 would be 4L60 and RPO MT1 a 4L80. Also, make sure you get one for a 4WD truck. The output shafts and extension housings are different between 2WD and 4WD. Also, 4L60 pan has 16 bolts, 4L80 pan has 17 bolts.
transmission question about switching 91 transmission with an 88 justgotwicked S-10 1 05-31-2005 10:29 AM
transmission questions SCMaxima2k Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 02-05-2002 09:43 AM
Transmission question Steel Engineering/ Technical 2 10-21-2001 02:56 PM
