Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 06-13-2011, 11:16 AM
sixwongs sixwongs is offline
1999 Saturn SL2 just started making clunk type sound
1999 Saturn SL2 just started making clunk type sound.
The noise only happens when the car starts the initial movement foward.
After you brake, the noise happens 90% of the time. just a clunk and you don't hear anything until the next time you brake.
Any ideas ?? something with calipers or a bearing ?
Thanks
Sixwongs
Old 06-13-2011, 02:46 PM
Cat Fuzz Cat Fuzz is offline
Re: 1999 Saturn SL2 just started making clunk type sound
The first thing I would check is the right side upper motor mount. It's on the passenger side right on top. When these go bad, they can allow the engine to clunk back and forth.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Old 07-10-2011, 06:01 PM
We found the problem the bolt stripped out of the sway bar. the bolt is completely stripped. I believe the threads on the stabilizer bar are stripped on the inside too.
I am trying to figure out the best way to do this repair.
Thanks
Sixwongs
1997 Saturn SL not starting DebbiR SC/SL/SW 19 07-17-2016 08:25 PM
1999 Saturn SL2 Cranks but Won't Start davmaj2 SC/SL/SW 8 08-31-2010 08:41 PM
1999 Saturn SL2 Rear Door Panel removal-frozen torque screws mgoldman9484 SC/SL/SW 3 01-20-2009 02:30 PM
1999 Saturn SL2 Crankshaft Position Sensor Location 95GMCJimmySLE SC/SL/SW 3 01-28-2008 09:16 AM
1999 Saturn SL2 Instrument Cluster Removal? AZ_home SC/SL/SW 0 10-18-2004 12:39 PM
