Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-12-2011, 11:11 PM
White_Stang_2006 White_Stang_2006 is offline
Electrical Issue
I replaced my car battery in June 2009 and again in December 2010; since the new batteries has been installed, I have had electrical issues with my vehicle. The interior and exterior lights flicker and the engine does a humming noise in harmony of the lights (exterior and interior) flickering. Does anyone know the cause of this issue?
Old 07-31-2011, 09:26 PM
mustangmike351c mustangmike351c is offline
Re: Electrical Issue
Its the alternator.
Old 08-14-2011, 02:36 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Why did you replace the batteries? That type of issue sounds to be an unplanned electrical draw. As mentioned above it could be the alternator. A quick flat rate method to test this is, whicle the vehicle is cold, turn the ignition on, but do not start. Let the vehicle sit for a few minutes and then place your hand on the alternator, if it's warm to the touch then chances are you have an internal regulator issue on the alternator drawing excessive current.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
01 Jimmy 4WD Strange Electrical Issue chobes Problem Diagnosis 3 12-29-2010 12:55 PM
New electrical issue Malacite69 Cavalier Problem Diagnosis 0 03-09-2010 03:33 PM
2001 ZR2 electrical issue airboss20 Problem Diagnosis 4 12-26-2009 08:59 PM
1998 Passat Electrical Issues mns247365 '97+ 2 05-22-2009 01:36 PM
2001 cav electrical issues Raeven Cavalier Problem Diagnosis 0 04-29-2009 10:23 AM
