Old 06-11-2011, 09:07 PM
trannyman52 trannyman52 is offline
Cannot shift out of park
97 F 150 2x4 will not shift out of park,,,,brake lights work,,,,,really need a good picture of where the shift solenoid is located on steering assy ,,,to replace or remove thankx gbaum
Old 06-12-2011, 06:43 PM
chamblizi chamblizi is offline
Re: Cannot shift out of park
check your t fluid and if you poorly maintain your t fluid you could have screwed your transmission smell your stick to see if the fluid smells burnt its probley shot but before making big moves change and or check your t fluid
Old 06-12-2011, 09:50 PM
The transmission is fine shifts perfect,,,the solenoid that unlocks shifter when brake is depressed does not function,,,not an electrical problem {brake lights work} fuse ok,,,just looking for a better diagram or advice to remove,,,replace solenoid gbaum
Old 06-13-2011, 08:42 AM
danielsatur danielsatur is offline
Where you parked on an incline without the parking brake on?
Try pushing the truck forward and shift into drive.
I like going from D to N, push the parking brake On, than into Parked pos.
Old 06-13-2011, 02:57 PM
broughy84's Avatar
broughy84 broughy84 is offline
I'm not real sure about the location of this solenoid but are you positive you have power going to it? I know you say the brake lights work and the fuse is good, but if you don't hear the click to unlock it I would try to trace the harness down and test it with a multimeter at the point of connection to the solenoid. Obviously without 12V+ you will not be able to unlock the shift linkage. Also, I may be mistaken but I would think this would have two power supplies to it. The brake light switch sends 12V+ to the solenoid as a signal, but then there is a Key ON power supply as well otherwise the lock would disengage even with the key off. I would double and triple check my power and grounds before throwing parts at it.
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 06-13-2011, 06:19 PM
mcmalloy mcmalloy is offline
It might have two switchs on the brake pedal one for the brake light and one for the tranny shifter .
Old 06-15-2011, 01:09 PM
Question why are you in our forms if you dont own a ford? Answer please
Old 06-15-2011, 01:30 PM
tempfixit tempfixit is offline
chamblizi, I for one did not know you had to own a specific vehicle to try to help someone.
Old 06-15-2011, 07:39 PM
Jaguar was a ford with problems, it was sold to Tata!
Old 06-16-2011, 12:37 AM
got it fixed today,,,,simply removed solenoid ,,,shifts fine ...now it is old school,,,don't need to depress brake to release shifter,,,,yea!!!!!!
p.s.you don't need to own a certain type of car to add a suggestion!!!!!
My personal favorite gas sucking thing to drive is my Dynamark riding mower !!!!!!!
Can't shift out of park mtammons MDX | Pilot 1 08-06-2009 02:50 PM
Cannot shift into Park hurricanes Grand Prix 8 10-29-2008 09:37 AM
Cannot shift into Park - problem with lock-release button Todd64 626/Capella/Capella Wagon 0 12-06-2005 03:43 PM
Cannot shift from park without shift release lamarr Celica 13 10-11-2005 09:10 AM
Cannot shift out of park!!!! novus43 Sentra | 200SX (USDM FWD) 1 06-11-2005 01:32 PM
