Old 06-10-2011, 07:29 PM
pfirstenhammer pfirstenhammer is offline
How do you remove the front rotors on a '96 Chevy 3500? Diagrams would be helpful.
I currently have the caliper off. The rotor itself is free, but it is being retained on the spindle by a hub of some sort. THis hub is stuck on and I can't seem to free it up. There are 8 studs that connect the hub to the rotor. THose are out. If anyone has a diagram or an exploded view of the assembly it would be incredibly helpful. Thanks.
Old 06-11-2011, 09:27 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: How do you remove the front rotors on a '96 Chevy 3500? Diagrams would be helpful.
Originally Posted by pfirstenhammer View Post
i currently have the caliper off. The rotor itself is free, but it is being retained on the spindle by a hub of some sort. This hub is stuck on and i can't seem to free it up. There are 8 studs that connect the hub to the rotor. Those are out. If anyone has a diagram or an exploded view of the assembly it would be incredibly helpful. Thanks.
2W OR 4W
Brake caliper bracket holding it on??
Some the wheel bearing hub has to come off if rotor is on back side of it.
MT
Old 06-11-2011, 11:19 AM
Originally Posted by MT-2500 View Post
2W OR 4W
How does that wheel bearing hub come off? I have the nut off. I won't come free. Do you have a diagram? I need an assembly view. Can you give me a website that has one?
Old 06-11-2011, 12:01 PM
MT-2500's Avatar
AF - Advisor
2W or 4W.???????
2W should have a dust cover .
Remove it and nut and washer and kotter pin aqnd pull off hub and rotor.
All data DIY should have pictures.
MT
Old 06-11-2011, 08:27 PM
777stickman 777stickman is offline
If it's a 4wd, look for 4 bolt heads on the back side.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 06-13-2011, 09:50 AM
ken_man_1 ken_man_1 is offline
My 99 3500 is 2wd, and it has front hubs. There are either 3 or 4 bolts holding the hub on, remove it. Once the hub is off, you can take off the rotor...
If it's 4wd, there is certainly a hub. Same as above. The hub can sure be a PITA to take off.
Old 06-21-2011, 12:25 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Sometimes the back side of the rotor fuses to the hub face with rust and/or around the hub center. There should be two threaded holes in the rotor you can thread bolts through to pop it loose from the hub.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
How do you remove the spoiler from the hatch? Sonic Eclipse Exterior and Wheels 3 10-08-2009 10:35 PM
How to remove the Front Bumper Safely alman87 Sierra 0 07-19-2006 12:32 PM
how do you remove the front door speakers?? nathan041286 Fiesta 0 04-30-2006 07:19 AM
How difficult is it to remove the front rotors? 99AccordCoupe Tires and Wheels 9 05-21-2002 07:54 PM
