Old 06-10-2011, 03:06 PM
TDWPgtp's Avatar
TDWPgtp TDWPgtp is offline
transmission slipping into 2nd
hey guys my tranny is slipping from first to second. i think its only when the engine is relatively cool. the bad part is that the transmission only has 30k on it...i got it 2 years ago. if its dead, im screwed because the warranty is up. any ideas? simple fix, i hope
Old 06-10-2011, 07:23 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: transmission slipping into 2nd
Hi,
When was the last time it was serviced? If it hasn't 30k is the normal interval so changing the fluid and filter would be the first thing.
NOTE you need to change the entire fluid. Not just a regular pan drop. Many users advise against flushing machines, the best DIY method is by disconnecting one of the lines from the radiator, start and idle the engine until pump starts to cavitate (flow becomes uneven), turn engine off and lower the pan; that way the amount of fluid will lessen preventing unnecessary spilling on the driveway.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 06-11-2011, 09:24 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Don't run it too long with no fluid.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 06-15-2011, 09:07 PM
TDWPgtp's Avatar
either i counted wrong before, or it has changed. it is now slipping from 2nd into 3rd. theres not really a delay in the shift as far as i can tell, but it is catching very abrubtly. deffinately too hard of a shift. anyway, my friend, who is an Audi mechanic, suggested trying "tranny no slip" which i assume is an additive for transmission fluid. does anyone have any experience with this product or know if it actually fixes problems, rather than hide their symptoms?
1995 Astro Transmission Slipping Dannoastro M Bodies 5 02-12-2011 01:07 PM
95 k1500 wont shift into 2nd.. found melted solenoids coreman30 C/K 9 01-18-2011 05:24 PM
1993 Olds Delta 88 Transmission slipped into neutral on it's own. PLEASE HELP ME!!! cadauctions Eighty Eight 3 01-04-2007 06:54 PM
'99 Blazer Transmission Shifting into 2nd and 3rd gear at High RPMs amazonpup Blazer 9 09-02-2004 10:32 PM
2001 i30t transmission slams into 2nd gear mookster1 Introductions 0 08-04-2004 07:07 PM
