Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 06-09-2011, 10:30 PM
dan03820 dan03820 is offline
2003 Tahoe A/C question
Hey guys
I have a 2003 chevy tahoe 5.3l with dual climate control the compresor clutch wont kick in. Was wondering if i could test the clutch by jumping the wires off of the low pressure switch on the reciever dryer and if their are diagrams available. At idle i had 75 low side and around 55 on high side. Something wrong here.
Thanks Dan
Old 06-10-2011, 02:01 PM
j cAT j cAT is offline
Re: 2003 Tahoe A/C question
Originally Posted by dan03820 View Post
Hey guys
Thanks Dan
first check fuses. then jump switch only for a time to see the clutch engage...pressures appear low ..with ac off and at 90 deg f should be 100 plus psi...switch should close above 10 psi. so using a ohmmeter with the connector removed measure the switch resistance should be zero a/c and engine OFF!
2003 Tahoe Keyless Entry Programming azjay Tahoe 3 03-12-2008 11:36 AM
2003 tahoe questions Scott Dog Tahoe 1 02-24-2007 12:31 AM
2003 Tahoe Exhaust smithwesson625 Tahoe 2 09-26-2004 05:54 PM
2003 Tahoe front clicking noise firemedicmike C/K 6 12-08-2003 08:00 PM
HELP! 2003 tahoe keyless remote programming rcline C/K 6 11-20-2003 10:38 AM
