Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 06-08-2011, 06:35 PM
vhandobi vhandobi is offline
Checking evaporator for leaks?
Does anyone know an easy way to check the evaporator for leaks that does not involve ripping the dash apart? I understand that I'd have to do this to replace the evaporator, but is there an easy way to push some dye in and visually inspect the core for leaks before I go through the trouble of taking everything apart? I've inspected the external components (lines, compressor, etc.) and can't find any trace of dye so am assuming it's the evaporator but would really hate to pull the dash and find no leaks in the evaporator.
Thanks in advance for any suggestions.
Old 06-08-2011, 09:42 PM
Scotty89's Avatar
Scotty89 Scotty89 is offline
Re: Checking evaporator for leaks?
The way i always check the front evaporators is by looking at the drain tube for it. If it is leaking more than likely there will be a trace of dye around the tube or the area the water runs down the underside of the car. When the evaporator sweats the water runs down the evaporator and runs out the tube usually taking dye with it.
Checking for leaking injectors steriosm Yukon 6 06-11-2008 09:02 AM
Evaporator Coil Leaking npye Caravan | Voyager 2 07-08-2006 02:07 AM
what does evaporation emission leak mean ellis1stop Taurus | Taurus Wagon 4 07-05-2006 06:26 PM
