Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 06-07-2011, 04:47 PM
jrandallc jrandallc is offline
Best way to clean engine with oil pan off?
I have a 2000 Grand Cherokee Laredo that I'm replacing the oil pump on. When I pulled the pan, I noticed that the oil in the pan and on the engine above the oil pan was very clumpy and thick...much more so than I'm comfortable with. I have to replace the oil pan anyway due to damage, so that part of it is getting resolved for me. My question is about cleaning the engine parts above the oil pan. Is there a safe treatment that I can use to spray and clean that area out before putting the oil pan back on? Should I just put the oil pan back on and let the new oil and filter do its job in cleaning? Thanks for any suggestions.
Old 06-26-2011, 10:58 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Best way to clean engine with oil pan off?
You could try to clean it (I don't know what you'd use) but a few particles of that crusty oil that break loose when you are cleaning could clog an oil gallery. I'd go with more frequent oil changes for awhile, with a couple of Auto-RX treatments.
Just curious -- has this always been your vehicle, and what oil and oil change interval have you been using?
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 01-14-2012, 12:47 AM
Raimundo Raimundo is offline
Brush, Hand, Diesel fuel and patiance,,,a lot
2000 GC 2WD - Remove oil pan without removing exhaust y-pipe? jrandallc Grand Cherokee | Grand Cherokee SRT8 0 06-05-2011 09:31 AM
Searching for a Ford Pinto oil pan Mr 14 Prozent Engineering/ Technical 0 05-25-2011 08:01 AM
Oil Pan Gasket? ken_man_1 F Series 8 12-03-2010 08:30 AM
To get oil pan off Drop front axle or pull engine ? scholzee Problem Diagnosis 3 05-07-2008 04:52 PM
Should oil pump be replaced along with oil pan? Wheel7 Crown Victoria 3 08-23-2007 05:57 PM
